M6 Offset Lever Roll Pin
I've been lurking for awhile here, but I think this is my official first post. I hope you won't think I'm an idiot, but I've created quite a mess for myself.
I have a 2000 F-body T56 in a 1970 El Camino. I bought it used, and it apparently doesn't have reverse (kicks out hard when the clutch is engaged). So, I started to take it apart today with the tranny still in the car - I probably have more room under the car than you guys are used to. Anyway, I got as far as the offset lever roll pin in the top of the tranny where the shifter ball does its thing. While trying to drive the pin out with a very inappropriate punch, the punch actually broke off inside the roll pin. The pin is part way out of the bottom of the offset lever, but not enough to grab with anything. I bought a set of roll pin punches, but it still won't budge any further. In the morning, I'm going to try to c-clamp the pin back in to see if the broken piece will come loose, but I'm not holding my breath. I also tried drilling, but that was definitely slow going since the punch is very hard steel. Am I completely screwed? Do any of you know of a good tool or techinique I can try? I'm getting my *** kicked by a $0.01 part.
Thanks,
Ryan
Are you just going to open the extension housing to fix reverse or are you planning on going into the main case as well?
