anyone using rps clutch?
Tim at RPS said the suggested retail should be around $3200.
RPS website shows $3495, but I'd guess you could probably pick on up for about $3000 at your supplier.
Yea alot of bread, but alot of clutch.
Regarding install, should fit right in where the stock clutch sits, no other mods necessary.
Yes, billet chromoly flywheel, ready to bolt in.
Quite expensive, but if I go the TT route on the z06, that's what I'm using.
And no, I'm certainly not loaded with $$$!
Just good insurance, one less thing to go wrong under the high hp.
For drag racing, the th400 is probably a better choice.
Isn't a 4l60/4l80 conversion available for the z06?
That's also a possibility for me.
