Grinding Problem
Old Jul 13, 2005 | 11:43 PM
Red_Dragon's Avatar
Default Grinding Problem
Whenever i shift into 3rd around redline it grinds a little bit going into gear but always goes in. This has happen with 4th and 5th too but 3rd is like everytime. Usually if i hold the clutch in longer and shift kinda slow it wont grind. Also if i just have the clutch pushed in and try and throw it back and forth between 2 and 3 it will grind the same way going into 3rd. Is my clutch just not disengaging or what? Also just to let u guys know my shift fork is probably a bit bent too, every once in a great while itll just pop out of 3rd. I have a 5.0 now but ya. Should i try and do the drill mod then bleed the system and see if that helps? Also where is the valve to bleed the system, or is there more to it than that? Thanx in advance
Old Jul 14, 2005 | 09:51 AM
777's Avatar
777
You need to get your synchros rebuilt. The same thing happened to me and it was like $1000. I had a full rebuild though.
Old Jul 14, 2005 | 02:04 PM
Red_Dragon's Avatar
Well that kinda sucks I'm pretty broke right now and if I do it I'd like to have everything upgraded. Anyone know some quality shops around Chicago? Is sending my core out for a rebuilt one with upgraded parts a bad idea?
Old Jul 14, 2005 | 02:08 PM
Red_Dragon's Avatar
How hard is it to replace synchros,would I be able to learn how to do it?
Old Jul 14, 2005 | 11:07 PM
Sigforty's Avatar
It is probably the blocker rings on the synchro packs. If you rebuild it I suggest some of the carbon based ones they are a little tougher. Other than that a steel shift fork would be a good investment if you plan further abuse.
Old Jul 15, 2005 | 05:08 AM
Red_Dragon's Avatar
Should I just do a synchro rebuilt kit and a steel 3/4 shift fork then and i should be all good? Should i considering replacing my 3rd gear also? I guess there goes some money for makin my car fast. Maybe ill just put a 4.10 in the rear and hope it lasts until winter.
