Clutch pedal not coming all the way back up??? What's up?
Old 08-12-2005 | 01:50 PM
  #61
A-Bomb's Avatar
Originally Posted by slpss9723
can this be covered by warranty.......mine only has about 17700on the clock and it has started doing this......
i would think so. is your car modded?
Old 07-17-2006 | 05:37 PM
  #62
TTPNick's Avatar
have you changed fluid? if so bleed it really good couple times
Old 07-17-2006 | 05:39 PM
  #63
bjamick's Avatar
ya man can u pump it and it will stiffen up a lil bit if thats the case its your slave cylinder prob set u back bout $50
Old 07-17-2006 | 05:46 PM
  #64
TTPNick's Avatar
have you changed fluid? if so bleed it really good couple times..and to bleed it theres a 11mm shaft on top of connector for master to slave. get shallow 11mm 1/4drive bleed like brakes remember to fill little clutch cup with dot 3 or youll have to do it again..
ttp nick
Old 07-26-2006 | 03:15 PM
  #65
asc83's Avatar
check your clutch spring, it could just be that, i had the same problem and i fixed it with a 40 dollar spring that i got from a dealership
Old 07-26-2006 | 03:25 PM
  #66
calhoon's Avatar
I would hope that this problem was solve back a year ago when the last meaningful post was made.
TTP nick whats up with digging up old ( OLD) threads?
