NEED HELP on bleeding master cylinder
"Check the reservoir again and top off if needed. Hold the clutch pedal to the floor and open the bleeder valve until the fluid flow slows way down. Release the clutch pedal and check the reservoir level. Top it off as needed. Press the clutch pedal again to the floor and hold it while opening the bleeder valve. Repeat this process until you get the normal feel back in the clutch pedal. We ended up just pumping my clutch pedal 30 or so times over and over until the feel came back to the pedal. "
Don't you people take anything apart to see how it works?
EDIT: Oops didnt see above....well this is just to reconfirm the above reply...
tomorrow morning!
I think I fucked my master cylinder up. You know that think goes in and out like piston, mine is not straight!!! Has angle
