A4 to M6 swap? Computer reflash?
Old 07-20-2005, 11:32 PM
SSmokeDaGT's Avatar
Default A4 to M6 swap? Computer reflash?
How much does that usually run you guys or can i just buy a M6 computer and toss that sucker in? Any help would be greatly appreciated..
Old 07-20-2005, 11:36 PM
Michael Ozorowsky's Avatar
Get HP Tuners, will allow you to reflash EASY
Old 07-21-2005, 07:27 AM
Griswold's Avatar
You can buy an M6 computer but it is not necessary. If you have a hookup at a dealer then they could do it for you. I have heard most dealers won't do this though. Your best bet is to find a local shop or just another owner with hptuners for the same year and get them to flash in an M6 file.
Old 07-21-2005, 02:11 PM
SSmokeDaGT's Avatar
How much is HP Tuners? How much do local shops usually do it for?
Old 07-21-2005, 04:38 PM
BillS's Avatar
We did a A4 to M6 conversion on a 98 a few yrs ago. We got a new PCM and had a Dealer with a tech II flash in the program of a M6 car we knew (it requieres a M6 VIN to be entered) Also the PCM conector required a few wires to be repinned to new holes( tool required)
Also if your area uses a ODB II inspection this can cause a problem as the PCM vin will not match the one on the car and reg. This causes an instant fail and reg cancilation in Mass.
