Was stuck in 4th gear
Old Jul 21, 2005 | 07:12 PM
ksk1980's Avatar
Default Was stuck in 4th gear
was stuck in 4th for about 5 days and then i finally got it out from what i understand the keys have either been crushed or broke. but now im having probs. w/ 3rd now. whats the deal ??? it was working fine foir about 4-5 days now it grinds like hell going into 3rd if it even goes , and when it does it kicks it bak out under light acceleration. Are the syncronizers completely gone and I also noticed a rattling noise under hard acceleration sounds just like a loose shift **** but its not i took it off and it still makes the same noise the trannys got 95000 miles on it HARD MILES that is !!! any help?????
I've been checking on www.gearbox.com for parts. is this a good place for parts ????? is their a seperate kit to rebuild the snycros. if so how much $$$$ am i lookin at?????
Old Jul 21, 2005 | 10:41 PM
SUX2BU's Avatar
3rd and 4th are the same syncro. you f up fourth then third goes too.
all you need is a basic $200 rebuild kit.
and stop using 3rd and 4th you are just causing more damage.
Old Jul 21, 2005 | 11:22 PM
Mike 01WS6's Avatar
I've got the same problem, but sometimes it gets stuck out of gear when I'm shifting gears.
Old Jul 23, 2005 | 08:11 AM
ksk1980's Avatar
but as far as the rattling noise would the snycro be causing that as well ????? and what all comes w/ the basic rebuild kit? I want to build the tranny so i WONT have this prob. again later down the road.
Old Jul 24, 2005 | 10:43 PM
jlwade's Avatar
where do you get the rebuild kits from my car 00 z-28 is doing the same thing grind into 3rd grind into 4th a local shop told me the shift forks were probably bent
