Squeaky Clutch Pedal
Old Jul 23, 2005 | 03:48 PM
slayer6x6's Avatar
Default Squeaky Clutch Pedal
Everytime my clutch pedal is slowly pressed or depressed it makes a squeaking noise. I tried to spray lube the linkage and the rod but it didnt really do anything. Anyone elese have this problem? Anyone have a solution?
Old Jul 23, 2005 | 03:55 PM
8-Pack's Avatar
Clutch return spring, very very common problem. Eventualy it will break and most people just leave them off, mine has been off for 6+ months no problems.
Old Jul 24, 2005 | 01:15 PM
slayer6x6's Avatar
I took the spring out and the pedal is still squeaking. It almost sounds like its coming from the push rod area.
Old Jul 24, 2005 | 02:45 PM
1sick'98WS6's Avatar
I have that same problem i just havent done anything about it yet but it would be nice to know what to do to get rid of it
Old Jul 24, 2005 | 11:00 PM
FIREHAWK #07's Avatar
same problem here.... have sprayed it several times with lube....
Old Jul 25, 2005 | 01:57 AM
LSWannabe's Avatar
Same prob.
Old Jul 25, 2005 | 04:56 PM
slayer6x6's Avatar
I guess there is no fix?
Old Jul 28, 2005 | 12:14 AM
Super Sport Beast's Avatar
I sprayed mine with WD-40 and absolutely no squeaking ever since !!!!
Old Jul 28, 2005 | 07:01 PM
gettinthere's Avatar
Mine squeaks too. I can't figure out what it is so I just turn up the radio.
Old Jul 28, 2005 | 08:42 PM
GTObsessor's Avatar
i got the same problem with my break peddal... but don't pay much attention to it.
Old Jul 29, 2005 | 11:56 AM
JD_Z28's Avatar
same prob here cant fix it, I tried lube dosent work, im guessing that it needs spayed inside that rubber boot where the hydrolic is.
Old Jul 31, 2005 | 07:14 PM
01red28's Avatar
I had a nosie would not call it a Squeak drove me crazy put everthing on that master cylinder to get it stop but you know the switch that gets push in to allows the car to start (black rectangle) put grease around it real good an have not heard a noise yet hope that help. Obviously mine made a noise when it was all the was depressed and then being let out
Attached Thumbnails Squeaky Clutch Pedal-dcp_1484.jpg   Squeaky Clutch Pedal-dcp_1485.jpg
Old Aug 2, 2005 | 05:03 PM
slayer6x6's Avatar
Ill look at the saftey switch tommrow and see if I can find anything.
Old Aug 3, 2005 | 05:09 PM
JRracing's Avatar
I have the same issue. Thanks fellaz.
Old Aug 4, 2005 | 12:06 AM
5w20's Avatar
clutch master cylinder?
Old Aug 4, 2005 | 02:46 AM
kev93z's Avatar
its that black plastic switch(starter switch i assume) the pedal hits like said above. i had put some grease on it a while back, but yesterday after reading this post i went out and really gooped it on all the way around, especially on top. no more creaking when i slowly release the pedal.
Old Aug 4, 2005 | 03:04 PM
aschichler's Avatar
I'm having the same problem with my Colorado ZQ8.
I tried spraying the rod and all the joints, and it still squeaks. I took it to the dealer, and they lubed it a little, and they said it was working perfectly normally. I know it didn't do that when it was new.
I'll try some of the suggestions on this thread, and hopefully I'll get it fixed, or at least not squeaking as much.
Old Nov 24, 2012 | 09:24 PM
DjinnWS6's Avatar
LoL that's what I've been doing but I can still hear it and feel it a little. I'm gonna lube it like a **** star tomorrow and see if that helps at all
