Skip Shift - Can it prevent an accidental 3rd to 2nd shift?
Yes, you should be able to set the CAGS enable speed to what ever you want. Also the range in between the TPS% of where it will be active and possibly RPMs. I mostly deal with A4s, but I recall you can set the CAGS to enable at different TPS%, RPM and/or speed (MPH). I am not sure if LS1-Edit can do that, but V1.7 of HPTuners can. Good luck!
