Digging deeper into the clutch stuck to the floor problem
Old 12-10-2005 | 03:20 AM
  #61
Robinator's Avatar
My clutch is broken in and I tested it out and..........(drum roll)............PROBLEM SOLVED
I am so happy right now This clutch grips like a mother too! It puts a huge shock through the drivetrain. When it engauges, it EGUAGES! My mystery is solved now and now I am moving on.
Old 12-10-2005 | 11:08 AM
  #62
whocares84's Avatar
i have a similer problem in my 00 ss. i have the mcleod master, the 02 slave, and a ram clutch. it is slipping in all gears but 1st if i try to stick it to the floor. if i ease into the throttle it does not slip. the clutch pedal is real mushy and it also gets stuck at the floor. i dont think it has to do with the clutch assembly because it still graps hardcore in 1st and graps if i ease into it in all the other gears. what do you all think it is? this whole system in about 2 years old.
