Clutch bench bleeding ?
Old Jan 22, 2002 | 02:19 PM
1madss's Avatar
Default Clutch bench bleeding ?
When bench bleeding the master/slave, do you need to have the slave compressed to bleed it? I tried just claming the slave in a vise and pumping the master, but I cant get any pressure. If I do need to have in compressed, do I need to worry about the uneven pressure on the throw out bearing from clamping only one side in the vise?
Thanks
Mark
