Hard to get into Gear
Old Aug 19, 2005 | 11:36 PM
Justin01SS's Avatar
Default Hard to get into Gear
Just had a new ram clutch put in with all the hydralics either replaced or modified. I go to drive my car and sometime the gears go in nicely, other times like at a stop, its hard as hell to get the car to say, go into first. Any idea what causes this to happen?
Justin
Old Aug 19, 2005 | 11:39 PM
Ferocity02's Avatar
Sounds like the clutch is not disengaging completely. Where is the engagement point of the clutch? Low, middle, or high? You might want to try bleeding the system and see if you can some more air out, especially since the hydraulics were replaced.
Old Aug 20, 2005 | 06:14 PM
Mike44138's Avatar
Probably air in the system. Definite clutch disengagement problem. Don't keep trying to force the tranny into gear unless you want to replace synchros/blocker rings/gears.
