not going into gears
If it goes into gearswhenthe engine is off, it's more than likely you hydraulics. Master/slave is shot. How does the clutch feel?
The teeth are the same as on the blocker rings. Also check the synchronizer assemblies & the collars for wear where they engage the clutch teeth.
Your gonna need blocker rings & a steel 3/4 fork minimum.
Download the service manual for free from TCC, search in here you'll find it.
Then as everyone says upgrade your hydraulics to protect the newly rebuilt trans.
