How to properly drive a stick...
Also, How do LS1 M6s compare to other stick cars? Are they easier or harder to drive than most? Ive also driven an early 90s saturn stick car, and a late 80s Nova. The Mirage and the Nova were easy, but the Saturn was tough...
If your coming to a stop use neutral, then put in gear when needed. Cant really compair front wheel remote mounted shifter 4 cylinders to a RWD V-8 car. But they all feel close to same(RWD) The only diffences I run into is the clutch feel.
I find that since it has close ratios the normal RPM drop during a shift causes the car to lurch unless I add some gas, something a wider ratio does not do.
That said, I find the LS1 cars very easy to drive due to the hydraulic clutch, but I've never really had any problems driving other cars, either. Just keep driving and practicing and you'll get a good feel for what you can and can't get away with when shifting.
Ryan
i recommend not to do any hard shifting in your ls1 until you get used to it for a couple weeks.
I always put her in neutral when I know I'm going to be stopped for more than a few seconds.
If I'm at a light, I'll push the clutch in and put it in 1st when I see the cross traffic light turn yellow (if I can see).
How many of you downshift when braking? I always do (good/bad?). I have pretty good brake wear, and my stock clutch disc still had almost 1/8" of material on either side before I replaced it with a SPEC III after 90k.
He's concerned about his throwout bearing... While you are idling with the clutch pushed in, you have the throwout bearing under load. Over much time, the bearing will wear out sooner.
The only vehicle I've owned that's easier to drive than the WS6 has to be our '85 Jeep CJ-7. That's only because it has a 4.03:1 1st gear and 4.56s in the axles.
I usually put the clutch in, and leave it there for the duration of the light, never had a problem with wearing out the throw out bearing in any manual I've ever had.
Downshifting when going around a turn, sometimes yes sometimes no, it's cheaper and easier to replace brake pads than a clutch, so take that FWIW
The biggest problem IMO is the stock shifter, it's like stirring a bucket of rocks with a stick, no real sense of what gear you're in, get one of the short sticks (UMI or Lous) and the stock Hurst is pretty good.
To re iterate, practice your 2-3 shift ALOT before you try it at redline, unless you like checking/replacing pushrods
I agree...when pulling away from a light when the road is crowded and moving slowly i usually don't even touch the gas pedal in my GTO until the clutch is all the way engaged. Torque is a beautiful thing.
try that in a gutless 4 cylinder.as for waiting at lights.....i usually coast down to the light in whatever gear i was last cruising in (except 6th of course, i'll drop it to 5th) and then throw it into neutral at around 20 mph (when the tach drops to around 1000-1100 RPM).
-Mike
one of the hardest cars i drive that was a manual was my friends 94 ford probe.
easiest car i drove was another friends 96 sebring
Anyway, I like to put it in neutral when i can to save wear on the T/O bearing and pressure plate and everything else. Not to mention if you ever get rearended, or if youre severely allergic to the bee that just flew in the window and you accidentally take your foot off the clutch, you wont lunge forward.
Do I Know how to properly drive a manual transmision car ?
I Guess I do,
I have 102,000 on the original clutch and it still grabs great.
Sometimes I put it in Neutral at stops and sometimes I don't.
I always downshift (Compression brake) the Car, I sometimes let the clutch out with No throttle input (Torque is a wonderfull thing)
I have Never dumped it at mile high RPM But I don't Baby it either.
Clutch has only slipped bad on me a couple of times because of the shitty Hydraulics.
