t56 help asap
Old Sep 1, 2005 | 10:49 AM
gueros2kss's Avatar
Default t56 help asap
I took my trans to some old man to fix, ive heard so many good things about him, my friends have taken him lots of buss, but when i take him my trans he gets something stuck up his ***. First he tells me he would have it done in two days, that turned into a week 1/2 of not answering my calls and a lot of b/s. Finally i get it back and put it in and went to drive it and it feels some kind of grinding noise even when i push the clutch in and the gears are hard to put in. I dont want to take it to that man cause im afraid im ganna kick his *** and use his head as a shift ****, I need someone who can check it out maybe fix whats wrong, im willing to pay i JUST WANT MY **** DONE RIGHT, if anyone can help it would keep me from kicking an old mans *** Thanks...
Old Sep 1, 2005 | 11:10 AM
calhoon's Avatar
I suggest before you go off on it or the old dude, you perform a proper hyd. system bleed. You need to be certain the clutch releases. Does it shift ok w/ engine off? THis would indicate clutch release issues. Bleeding beats yanking the trans. again.
Old Sep 1, 2005 | 04:10 PM
gueros2kss's Avatar
Default t56 help
i tried it a few times and most of the time they went in smooth it didnt go all the way in on 4th and 5th a few times. i was also driving it and it poped out of third
Old Sep 2, 2005 | 06:42 AM
calhoon's Avatar
A 3rd jump out sound slike he put your old 3/4 fork back in. That or the unit was shimmed too loose. Ask if he put a new( hopefully iron) 3/4 fork in the build.
Old Sep 2, 2005 | 12:57 PM
gueros2kss's Avatar
Default t56 help
i will ask him, thanks for your help
