What is this drill mod? For Slave Cylendar?
I can't shift at the track, I think my Slave Cylendar is bad... I'm going to change it, can anyone give me detailed info on this? Anything else I should do while changing this?
They have a good detail write up on the drill mod here http://www.installuniversity.com/ins...sity/index.htm
My shifter would lock up from time to time and I wasn't sure if it was the slave or the master so I bought an 01+ (288) slave and a McLeod adjustable master. While I was at I bought the Z06 clutch kit for $350 and did it all at the same time. When I had it all apart I did the drill mod for good measure. Havinng that extra fluid flow through the line makes a big difference. The whole project was a lot of work but in the end it's much easier to drive and grabs gears pretty damn hard
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
