Back to Dexron III from Red Line syn - Shifts much better now
Just wanted to share with everyone that I replaced the tranny fluid with Red Line synthetic awhile back. I noticed right away that gears started to grind under fast shifting and also when the car was cold. It was also harder to push/pull into a gear.
I read on a thread that others have experienced this and went back to OEM spec which resolved it. I am another believer.
Yesterday I replaced the fluid with the OEM reccomended Dexron III. I forgot how nice it shifted and is back the way it was before. Nice easy shifting and no grinding.
I'm new to f-bodies here. Where do I drain the trans, and where do I fill it? How much does it take?
I've noticed it grinds every once in a while when I shift to 2nd hard...Also is kind of rough going into gears. I'm sure the fluid needs to be changed...That would probably help quite a bit since I'm sure it was never done before.
If you have a manual trans then the drain plug is in the rear part of the tranny towards the bottom. The fill plug more towards the front an up higher. You can't miss them. They are the only things that look like they unscrew.
There is no way to put a funnel in the fill hole and pour in tranny fluid, no room. Some take like a mustard bottle, fill that and spray it in. I run a hose from the top of the engine compartment down to the fill hole and pour it into the hose using a funnel. This might take longer.
Once fluid starts coming out the fill hole it is full. Should take a little less then 4 quarts.
I'm a believer in using the Auto Zone cheap tranny fluid. Never had a problem and my car sees way more track time than street. Well, I had one problem, the output shaft broke on a 6000 launch. I don't think the fluid had anything to do with that!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
