Z06 clutch???
Old Sep 16, 2005 | 12:00 AM
Starz T/A 17's Avatar
Default Z06 clutch???
Where can you get this clutch? ive looked at a few of the sponsers and cant find it anywhere? found A link to GMpartsdirect and it says will only fit Z06 model vettes. Is there a different one for F bodies or will this work?
And im debating this or a Spec 3 clutch, I go to the track now and then but not every week. is there that much difference in the 2 clutches?
thank you
Old Sep 16, 2005 | 12:18 AM
PHeNoM Z28's Avatar
I just bought it on gmpartsdirect.com...the Z06 clutch, pressureplate, and flywheel package and I bought the Z06 slave seperate. It tallied up to $515 or somewhere around there.
Old Sep 16, 2005 | 09:54 AM
chadtn's Avatar
thank you
The Z06 clutch is an excellent driver clutch...I'd run it on anything I didn't plan on racing. If you're going to take it to the track I would go with the Spec stage III...I've been running one in my 02 Camaro and 93 Mustang for a while now with no problems at all.
Good luck!
Chad
Old Sep 16, 2005 | 10:20 AM
NLinnear's Avatar
Good luck!
Chad
Couldn't have said it better myself I have the Spec stage3F (iron disk). Great holding power and good street manners.
Old Sep 16, 2005 | 06:42 PM
hammerhead's Avatar
I got mine through my dealer, but Pace has 'em- & at good prices too. PN is 12570806. Upgrade the slave too while you're in there PN: 15046288
Old Sep 16, 2005 | 06:50 PM
andypdbz's Avatar
how much is the spec stage 3 clutch?
as in the whole package
Old Sep 16, 2005 | 09:48 PM
Norrie's Avatar
I'm looking at purchasing the Z06 clutch as well. Two questions though, do I need the slave cylinder if I have a 2002 Z28? Second, what is a good/excellent aluminum flywheel that would work well with this clutch (i.e. no chatter)?
I'm currently pushing 400 rwhp, 376 rwtq but it's only driven on the street.
Old Sep 16, 2005 | 09:55 PM
Whats Pace looked through the sponsers and didnt see it? am i just missing it or where else can you get the Z06 clutch?
Old Sep 16, 2005 | 10:02 PM
Norrie's Avatar
Scoggin Dickey sells the Z06 clutch
Old Sep 16, 2005 | 10:41 PM
Thanks
Old Sep 17, 2005 | 12:12 AM
01SLPSS's Avatar
The Z06 Clutch is a great clutch, never had any problems with it, beating on it constantly, and doing 6K dumps at the track/street, only reason replaced it was cause tranny broke and while I had it out wanted to upgrade to the Spec 3i clutch for other future HP plans!!!! Both Great Clutches!!!!!
Old Sep 17, 2005 | 03:15 PM
TARZAN's Avatar
Thanks for the info guys, I was curious as well!!!
-Will
Old Sep 17, 2005 | 06:48 PM
GTO_Scott's Avatar
If you prefer a stock style clutch, you may consider getting an LS-7 clutch, pressure plate, and LS2 flywheel - a bit over $500. Would be a better choice over an LS-6 clutch setup.
https://ls1tech.com/forums/generation-iv-internal-engine/368318-ls7-clutch-pics.html
Old Sep 19, 2005 | 10:38 AM
So the Z06 clutch part # 12570806 will bolt up directly to my 00 LS1 right?
