Best M6 60'
Originally Posted by 01SLPSS
What Suspension Upgrades Do I Have.... What Don't I Have is the Question......No K-Member, thats it!!!!!
Launch Rpm Ranging From 4,500 to 6,000![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I do not know about stock tires but with Mickey Tompson Sportsman Pro tires. I cut a 1.67 and scatered my stock clutch at the 1/8 mile on that 1/4 mile run.
It made me want to
It made me want to
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
Originally Posted by GETGONE
So what's holding your motor and suspension in if you dont' have a K member? You're saying you replaced it and just losing the 30lbs or so from that allow you to pull the front wheels off with only Nittos? I kinda doubt that.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#32
I usually could cut a 1.8 on the stock clutch at a track with decent track prep and a 1.9 at the local 1/8 mile tracks that did nothing. I was running kumos. The stock clutch did not like that much. I am still waiting to test the new stage 5 spec to see what it will do with some nittos.
#33
Low 1.9s to high 2.1s on a 2000 Z28 with 4.10s/10 bolt with 275/40 17 KDs (200 treadwear) at 22 psi, about 25K on the stock clutch with NO slipping, just releasing it real quick at about 2000-2500 rpm. Later on with same size Nitto DRs at 14-17 psi (still full size fronts) and about 45-50K on the stock clutch I pulled very high 1.7s to mid 1.8s, 2500-3000 rev launch, again no slipping (you cannot with these Valeo p.o.s.).
#35
damn, all i can get is 2.25 sixty foot's...i go from about 1500 rpms, would go a little higher but i dont want to overdo it and spin. plus my tires are 5/32 and 6/32 tread....how bad is that tread??
#36
2.115s 60' on Kuhmo All Weather tires. 45F (Last weekend at US41). Completely stock motor, trans & tires. Launching @ 2500 RPM with IRS. 3000 RPM got me spinning real well @ 2.568 - lots of wheel hop!
