Best M6 60'
Old 09-22-2005, 06:19 AM
02 BLK WS6's Avatar
Default Best M6 60'
I am looking to see what everyone's best 60' have been with stock tires and stock clutch.
Old 09-22-2005, 01:46 PM
grubby98's Avatar
mine was 2.4 I think. but that was the first time to ever race a m6. since then i put some drag radials on, and the best i have pulled so far is a 2.0 and that is a stock clutch on a 98 z28 with 50xxx.
Old 09-22-2005, 01:54 PM
pontiac's Avatar
stock clutch and tires 2.0
Old 09-22-2005, 02:28 PM
GETGONE's Avatar
Usually pull 2.0-2.1's but have had a couple 1.98's and a 1.975 on the stock Goodyear's. Tire pressure doesn't seem to matter. Have gotten 1.98's with them at 32psi. Tired 26psi and was mostly 2.0 but did pull off the 1.975 with the pressure lowered.
Old 09-22-2005, 02:29 PM
TroubledWine3's Avatar
2.15 with slipping stock clutch at 105k miles on BFG KDWS 245/50/16s.
Old 09-22-2005, 02:35 PM
2001SSpewtm6's Avatar
stock clutch and tires 2.16
Old 09-22-2005, 03:07 PM
scrmnws6's Avatar
Spec stage II clutch, 4.10 gears, 315/35/17 rear tires...managed a best of 2.13!
Old 09-22-2005, 03:49 PM
1BAD02WS6's Avatar
1.91s went a 12.4@116
vortec_7's Avatar
Wow...maybe I should've went with an auto.
Old 09-22-2005, 03:52 PM
redline2k's Avatar
1.89 at orlando speedworld.
Old 09-22-2005, 04:18 PM
MattIROC's Avatar
2.02 60ft w/ 4.10's and nittos and stock clutch (unsure of mileage)
Old 09-22-2005, 10:23 PM
Letsndy's Avatar
consistent 1.9's spec 3 and nitto 315's
Old 09-22-2005, 11:02 PM
MagikMan's Avatar
Stock clutch and runflats, consistantly under a 2.04. Sometimes hit the 1.9's.
Old 09-22-2005, 11:51 PM
black00TA's Avatar
LS1Tech 20 Year Member
2.0 with 4.10's on stock clutch with 76k miles, on 245/50/16 Fuzion ZRi's
Old 09-23-2005, 12:11 AM
warrenss's Avatar
went 1.72 with kuhmo street tires spec stage 2 i did slip the clucth to get those good 60' 6 speed 4 10 gears
Old 09-23-2005, 01:29 AM
BriancWS6's Avatar
Stock 3.42 gears, stock clutch, Yokahama street tires, last time to track pulled 1.939, backed it up with a 1.935 Trip before that they were all 2.0s
01SLPSS's Avatar
1.74 60 ft w/ Stock Clutch, 275 Nittos, & 4.10's!!!!!!
Was Running 1.7X 60Fts All Day long!!!!!
And was Pullin The Tires off the Ground Every Run as Well!!!!
Old 09-23-2005, 01:38 AM
BriancWS6's Avatar
What suspension upgrades do you have? What was your launch rpm/technique on these runs? I will be happy if I could pull 1.7s after I get a new clutch and mount the DRs back up.
Old 09-23-2005, 01:42 AM
01SLPSS's Avatar
What Suspension Upgrades Do I Have.... What Don't I Have is the Question......No K-Member, thats it!!!!!
Launch Rpm Ranging From 4,500 to 6,000
Old 09-23-2005, 02:30 AM
black00TA's Avatar
if i tried to launch 4,500 to 6,000 on my street tires at the track i would blow my rear-end again.
i would be lucky to get off the line clean with 2,500 maybe 3,000
me and my 10bolt
