aussie vs. ls7 vs. ls6
ls7 clutch kit ls2 fly wheel and master and slave abounr 850 or so
aussie clutch kit 1000
i want a clutch thats gonna last a long time, good street mannors, and will take a beating, and dosent make a noise.
but 1 queston, does that ausie clutch kit come with every thing?
cluch disk, p/p plate, pilot bearing, throw out bearing, master and slave?
and what master and slave should i use if i go w/ the ls7 clutch
call jeff at 9728141800
he is in texas, or go to the web site for the 800 number. you will be talk to peter and he is 7 hours behind central time
A. OEM (OZ700oem)
B. 18lb Steel Billet (OZ700sb)
C. 8.8lb Aluminum Billet OZ700ab)
Kit contains;
1. Pilot Bearing
2. Flywheel
3. ARP Flywheel Bolts
4. Clutch Plate
5. Pressure Plate
6. Pressure Plate Bolts
7. Thrust Race/ Throw Out Bearing
8. Slave Cylinder
9. Install Alignment Tool
10. All Digitally Balanced & Ready to Install
Current forum sponsors who are distributors of these products;
(alphabetically)
A&A Corvette
Byun Speed
Fastech
LG Motorsports
Scoggin Dickey Part Center (SPDC)
LS7 clutch is good for a H/C street car, with maybe a little strip
Textralia is good for a TON of power, street and strip, drives like stock
ls6
ls7
aussie?
i dont have any super serious mods planed and if i do go boost or n02 then ide sway the clutch out again is needed to. this is a dd that gets driven hard
