M6 guys I need a little help....
Old Feb 10, 2002 | 08:43 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Default M6 guys I need a little help....
My problem started today.
The car drives fine on the street and 60's like a bitch 1.57 <img src="gr_eek2.gif" border="0"> but when I go to shift @ high RPMs no dice!
I think it may be the slave going bad or the T/O bearing hanging up.
I need some input.
I know it's definitely not a slipping clutch, because the car pulls both front tires 6" off the ground.
Thanks! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 10, 2002 | 09:06 PM
VINCE's Avatar
Shorty Director
Default Re: M6 guys I need a little help....
My car does a similar do dad.. I have a brand new TO bearing you can have.. <img src="gr_stretch.gif" border="0"> I wont need it with the new slave.
Old Feb 11, 2002 | 03:56 AM
Ghost SS's Avatar
Try adjusting the slave cylinder rod. I had a similiar problem but once I got under the dash to adjust the foot pedal everything was fine.
Old Feb 11, 2002 | 09:47 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Probably just need to adjust the pedal, sounds like you are not disengaging the clutch enough. Extend the master rod just a bit.
Tony
Old Feb 11, 2002 | 11:35 AM
Thanks for the replies guys. I just got off the phone with Dave @ Cartek and he agreed that the rod needed to be extended. It feels better when I shift @ 6800 now on the street, the true test will be @ the track. I'll make sure I have a 7/16 wrench and a pair of vice grips next time <img src="gr_sad.gif" border="0"> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Feb 14, 2002 | 06:57 PM
Tony have you changed the clutch fluid since you've had your Cartek clutch?
And where do you have the pedal engaging?
I have mine set to begin engaging 1/2 way through the travel and full engagement is 3/4 travel.
I don't know how much heat the fluid that Cartek uses can take but it seems like the fluid is boiling. On the street I can shift @ 6800 but @ the track it acts up especially with a big burnout.
What do you think?????
Old Feb 14, 2002 | 07:48 PM
VINCE's Avatar
Shorty Director
Richie whats up? The Centerforce DF is in the car. Without Al's help I would still be under the car now.. Cartek uses Dot5 fluid.. Suppose to not get hot.. My clutch disk was fine, but my pressure plate and flywheel were shot. My TO bearing was shot as well. I am glad I have that changed..
Old Feb 14, 2002 | 10:05 PM
Cool! How does it feel?
Remember to do the break in. 500 miles with alot of stop and go type driving or 500 engagements/disengagements.
Are you still coming for the spring change? <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Feb 15, 2002 | 12:34 AM
VINCE's Avatar
Shorty Director
Of course I am still coming for the spring change.. I just need a place to stay secondary to me staying in Orlando for the night.. Hook me up with a good cheap hotel in the Red Light District.. <img src="gr_stretch.gif" border="0">
Old Feb 15, 2002 | 03:42 PM
HAHA! Only real men drive M6's! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 15, 2002 | 07:28 PM
TexassTA's Avatar
[quote]Originally posted by Richie Carbone:
<strong>HAHA! Only real men drive M6's! <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" /> </strong><hr></blockquote> I hear ya man!!
Old Feb 15, 2002 | 08:38 PM
1madss's Avatar
Richie,
I'm hardly an expert, but I'll offer my .02 <img src="gr_stretch.gif" border="0"> . It surely sounds like a disengagement problem. I would agree with the idea of raising the pedal. Just be carefull not to raise it to high. This is how I toasted mine. As far as the fluid, it is DOT5. When I did my lastest clutch I flushed the system with fresh and the bleed it well after doing the drillout. The bad part is the damn fluid is 11.00 a pint. It does't take much though.
Good Luck
Mark
BTW;
[quote]HAHA! Only real men drive M6's! <hr></blockquote>
AMEN to that <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Old Feb 16, 2002 | 12:59 AM
MacGyver's Avatar
Richie when you gonna stop throwing money at your tranny/clutch and put in a TH400 like me <img src="gr_grin.gif" border="0"> If you want to run with the big boys...you need big parts
Old Feb 17, 2002 | 08:28 AM
Well it looks like the tranny is fucked. I bled the fluid and replaced it with Super Blue DOT 4 racing fluid. There was a decent amount of air still trapped in the system. The clutch is still holding like a mother though, even at our ghetto *** track here in Orlando I still cut another 1.57 60' <img src="gr_eek2.gif" border="0">
It might be a bent shift fork. I have someone local that can fix it. <img src="gr_grin.gif" border="0">
<img src="graemlins/gr_guns.gif" border="0" alt="[guns]" /> A4's <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
Old Feb 17, 2002 | 06:41 PM
VINCE's Avatar
Shorty Director
Good luck with getting the tranny fixed. I cant wait to see you start getting good runs again..
Old Feb 19, 2002 | 06:24 AM
cablebandit's Avatar
You dont have a shifter with stops that could be misadjusted do you?
Old Feb 19, 2002 | 08:32 AM
I have the Pro 5.0 but I have the stops turned all the way out. The T56 has it's own internal stops. It's definitely something in the tranny. That's theprice I have to pay for having a manly transmission. <img src="gr_grin.gif" border="0"> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
