Do You Need A New Flywheel With A New Clutch??
I am about to buy a clutch, but I am not sure if I need to spend the money on a flywheel also. I found a LUK online for $450 with all clutch things and a flywheel. But on Ebay there is a SPEC stage 1 for $290, just the clutch and everything that goes with it. Do I need to buy a flywheel with a new clutch system? And do I have to buy a new master slave cylinder? Any help is appreciated, thanks!
10 Second Moderator
Originally Posted by 01ls1
You can have yours machined...
If you get it turned dont forget to have it balanced. You will shake like a dog $hitting razer blades if you dont. Good luck, Tom
Originally Posted by Torkman15
Yes you can have it machined but you will spend as much money in machining and balancing as you would getting a new GM piece.
You do not need to replace your flywheel when you use a new clutch. You have a '99 car, it would not hurt to buy a new master and slave cylinder (replacing one without the other is futile unless one of them has gone bad for sure). I have an '00 car and after a while I could no longer shift into 2nd gear at wide open throttle because of failing hydraulics...needless to say when I went for the stage 2 I bought a new master & slave.
10 Second Moderator
Originally Posted by badazz81z28
Where do you get your machine work done? I have never paid more than $32 to have one resurfaced. Balanced? Not required nor necesssary..
I bought the flywheel (new GM piece) from SLP for $50.00 but it was a sale price so you might not get your new one for less than what you can turn yours for.
Do a search, get more info on these clutches and hydraulics and you wont be sorry. Good luck, Tom
