replacing input shaft
Joe
Joe
But it helps do know how things go together in there
The input shaft is also your 4th gear.
The new input shaft will need a Bearing pressed onto it.
But it can be down with out totally dissassembling the tranny.
You would need to have it held up by a friend on its tail shaft to do it.
Putting it together will be fun, for you will have to line up the Main shaft , the secondary shaft, the Main shift rod and the reverse /5-6 shift rod.
