What is going on with my cltuch!
Ok, so this is the second time this has happened. Both times it was during "spirited" driving conditions. The clutch pedal momentarily sticks just as I'm coming off of the pedal. Right about the point the clutch is fully engaged. It basically sticks then pops up to its normal height. Then, the pedal feels a a little soft.
Every gear shifts fine and I notice zero slippage. I have a Z06 clutch (could be an 01 - 02 f-body clutch, but I asked for a Z06 clutch when I bought it). Any way it has about 8000 miles on it with about 15 - 20 passes down the 1/4 mile without DRs or slicks. When I replaced the clutch I did the slave, throughout, pilot, and flywheel of course (all GM parts except the pilot which is a bronze bushing). Also, I had the tranny rebuilt at the same time, just cause it was free (Used and abused the carmax warranty - .
Anyway, I didn't do the master cylinder, could that be the problem? If not does anyone know what this could be?
Thanks
Thanks
