disengaging problems
Old Oct 20, 2005 | 07:43 PM
Howie White's Avatar
Default disengaging problems
i just bought a dual friction center-force clutch and i have bled and bled my clutch but the clutch still will not disengauge
i have a 2000 ss camaro with the ls1 and 6 speed
Old Oct 20, 2005 | 08:33 PM
SPEEDYws6's Avatar
I'm not too familiar with center force, but you most likely need to shim your slave or get an adjustable master cylinder. Has your flywheel been resufaced?
Old Oct 20, 2005 | 08:55 PM
where can you get the slave shims at
Old Oct 20, 2005 | 08:56 PM
btw yes i did resurface the flywheel
Old Oct 23, 2005 | 03:57 AM
N3V3RL8T's Avatar
I need to know where to get some shims too.
Old Oct 23, 2005 | 07:27 AM
98TADRIVER's Avatar
i had the same problems with my spec about 13k miles later. but she burnt up on me a lil bit. i took the expensive route (new stage 3, new flywheel, new mcleod adjustable master cylinder, and slave) that ran me about 1150 with shipping. but Ill never have to mess with it again!!! and the stage 3 is good for 680 hp, lol. ill never push that much hp. my parts should be in wednesday
Old Oct 23, 2005 | 01:48 PM
SPEEDYws6's Avatar
How much was taken off of your flywheel?
