View Poll Results: Which clutch to buy?
Spec stage 2
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
2
22.22%
Spec stage 3
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
7
77.78%
Voters: 9. You may not vote on this poll
SPEC 2 or SPEC 3- Help Me Pick one!
Hi,
I have a 1999 W5.6 TA M6, and I was wondering what clutch to buy. I currently have a stock clutch. Im getting a really bad burning smell off of a hard launch, and when press the clutch in it makes all kinds of noises. My car is a daily driver, with only an exhaust, y-pipe, MAF, air lid. Down the road I will prob get headers and a intake manifold. My question is, would the Spec 2 or 3 be better for me? I want the peddle to feel the same as stock and not be to stiff. I go to the track maybe 3 times a year, so about 15 passes. Which should I buy? Thanks!
I've been recommended a stage 2+ and that will be sufficient for heads and cam. mainly for street use, but track use sometimes. I believe the stage 2+ is good to around ~500hp, stage 3 is 680, kinda overkill there.
Stage 2 gets my vote, im ordering mine monday.
Moderator
3F (Iron disc)
![](http://i3.photobucket.com/albums/y63/dgrundwalski/Picture016.jpg)
Rides just like stock, Hooks like mad on the track. No problems slipping it at all in city traffic. I work in a city and drive 15 min in the city every day stop & go traffic to get tothe highway and no issues at all.
Moderator
![](http://i3.photobucket.com/albums/y63/dgrundwalski/Picture026.jpg)
Doing the deed at a friends house. Gotta love air tools.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://i3.photobucket.com/albums/y63/dgrundwalski/Picture022.jpg)
Put a new master & slave in while we were there.
![](http://i3.photobucket.com/albums/y63/dgrundwalski/Picture020.jpg)
Good time to replace the shifter too. I already had the Hurst, so just did a UMI short stick
![](http://i3.photobucket.com/albums/y63/dgrundwalski/Picture019.jpg)
i just put the spec stage 3 in my car along with the mcleod upgraded slave cylinder and i couldnt be happier. the pedal doesnt kill my leg with the updated slave in it. is definately grabbier i love it. its behavior is a lil different but its not like on/off. i put 220 miles onn it so far and im already used to it. spend 20 dollars more and get the spec stage 3!! you can find a great deal on it at www.EADPerfomance.com. i think its like 385.00 then the slave cylinder is like 129.00 everyone else is selling the specs for alot more
Just got stage 2 installed today. The good: light pedal feel, grabs like hell. The bad: vibration at idle and pretty much at all times when clutch is not engaged. Hopefully, this will go away with time.
I still have to brake in mine... maybe it will change
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
Where does your stage 2 disingage? Mine is way too in the pedal movement ( floor). Those days I'm modifying the master cylinder hoping it will help (adjustable).
