Cheap T56
Old Oct 31, 2005 | 02:24 PM
z28guy1999's Avatar
Default Cheap T56
Well after having my car for four months the tranny finally went. When i got the car it had trouble shifting into fifth, it progressed from there. I pulled my trans and tore it down last wednesday. Fifth sixth and reverse are gone. The pilot bearing was nowhere to be found, although i believe it came out and was thrown around inside my bellhousing because there are alot of marks on the BH and the pressure plate. First-fourth gear are about to go out so i figured it is time for a new trans.
My question is where is the best and cheapest place to get one?
Old Oct 31, 2005 | 03:39 PM
ls1 joe's Avatar
Are you looking for a stock one or rebuild with upgraded parts?
Old Oct 31, 2005 | 04:55 PM
badcompanyvpws6's Avatar
i am also in need of a stock t56. i have the everything but the tranny is the only thing i need and need one asap.
Old Oct 31, 2005 | 09:31 PM
wrencher's Avatar
wrencher
Well you can get entire trans's from www.ddperformance.com
but their not cheap anywhere. How bad is this trans, you can get all the speed gears & syncro assemblies for alot less than the whole trans.
