Resurfaced stock flywheel and Spec clutch?
Old 11-04-2005, 11:33 AM
tici's Avatar
Default Resurfaced stock flywheel and Spec clutch?
Resurfaced stock flywheel and Spec clutch? Will this work?
Is there something special I have to be careful at? like shimming the slave cylinder for the lost flywheel thickness?
I recently swapped the A4 with a M6 and at idle the engine is shaking more than before (I had the stock converter).
I have the Spec steel flywheel and I think it's lighter than the stocker.
Will this cause the vibrations?
In this case I would install the stock -resurfaced- flywheel. I just don't know if the Spec clutch + pressure plate will work. Any idea?
Thanks - Stefano
Old 11-05-2005, 08:26 AM
camarokid94's Avatar
i did it and it worked i had a spec 3 clutch and 4 pressure plate and my stock flywheel resurfaced. i burnt it up on a 200shot run but it worked great till then. use to have mcleod single dick and alum flywheel . plan on have that rebuilt this winter i liked the alum flywheel much better.
Old 11-06-2005, 02:14 PM
tici's Avatar
Can a lighter flywheel cause some vibrations compared to the stocker?
Old 11-06-2005, 03:12 PM
Mr. Luos's Avatar
Did you use a shim??
You told us you did it but never really answered anything he asked.
I am wondering the same thing. About the install everything including the new SPEC clutch and I had the stock flywheel resurfaced.
Old 11-07-2005, 10:18 AM
no shimms sorry
Old 11-07-2005, 04:46 PM
tici's Avatar
Any chatter with the Spec clutch?
Was it better after resurfacing the stock flywheel?
