Any extra time needed to drop a manual trans w/ LT's on it
Is there a big problem in time or any additional time needed to drop a manual transmission from an '02 camaro with longtubes on it w/ y-pipe and cats?
I think its actually less time because I dont think you have to pull the y-pipe. I was up under my car yesterday and the transmission looks like it can fit coming down no problem.
I left my Y pipe attached when pulling my trans out. Jet Hot LTs, QTP Catted Y. Like was mentioned before the car will have to be higher in the air as the trans comes down at a steeper angle than if the Y is removed.
