SKip shift Eliminator dead?
Manny
Even if you didn't put anything in there the solenoid wouldn't operate, as it would have no power (although you'd have a service vehicle light on)
Recheck the installation, look on install university for some instructions (with pics) that are better than the SLP ones
Well following what you said and with the help of install university it works now. I read the SLP instructions again to see where I might have misread it but looks like the instuctions are actually wrong. Also the part is alot different from what I've seen in pictures on the net and the paper they gave me. Weird.
Well since I first did this like a few months ago and just now rectifiing the problem I forgot where the other plug goes into. Any thoughts? Everything seems to work, but maybe it is the reverse lock out as someone had mentioned? Either way thanks guys for your help!
Buy some resistors at Radioshack for like 99 cents, shove it in the plug, tape it up, same thing as the eliminators you can buy, just not as pretty. They have an article on it on install unversity.
