22174970 Stock Trans Mount
My M6 trans mount was getting soft and starting to tear. I tried an ES Poly mount and it made my car sound like an 8 cylinder Diesel running on 6 cylinders. I bought a new stock mount part number 22174970 and the weird thing is it looks to be about 1/4" to 1/3" taller than the stock one I took out. At first I thought it was just that the old mount had worn out, but it sure looks like the base of the mount looks a lot shorter on the old one. Are there more than one tranny mount for a F-body? Is there one mount for an auto and one for an M6?
I went ahead and put in the new mount and the only trouble is it moves the Y pipe up slightly causing it to bump the body when I get clutch chatter.
BUMP for question about same part number:
Everything I'm finding indicates 22174970 is a mount for an automatic trans. Is it the same part number for the M6?
If not, I'd like to know the OE part number for the '98-'02 F-Body M6 stock rubber mount. Can't seem to find it.
Thanks.
Tipsy
Thanks.
Tipsy
