HELP!!!! B&M Ripper shifter
I have a little problem i have ran in to.I took out the hurst shifter that came with my car, I replaced it with the B&m ripper short shifter i did it myself everything is good 1,2, but when i am in 3 Gear it pops out of gear when i shift it into 3 i dont know whats could be the problem i dont want to jack up my transmission but all the other greats shift into smooth ...anyone give me some advise that would be great
thanks joe
thanks joe
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
When I instaled my B&M Ripper shifter I could only use the even number gears (2,4,6) and it would pop
out of gear when I would try to use the odd numbered gears (1,3,5). I fixed this problem by double cheking how the washers for the bolts were installed so that the shifter was centered in the opening. I then backed the stop all the way out, put the car in 3rd gear and then set the stop. Adjusting the stop is what cured my problem.
I hope this helps... <img src="gr_stretch.gif" border="0">
