M6 and line-lock?
Old Nov 28, 2005 | 10:21 PM
HowellSoccer88's Avatar
Question M6 and line-lock?
Probably a dumb question but how does the line-lock work with the M6? Is it as easy as it seems? Just floor it and heat them up?
Old Nov 28, 2005 | 10:26 PM
glennster's Avatar
2nd gear,pump brake and engage line lock,rev and dump at the same time and hold RPM about 5k or enough not to bog the engine,count to 5 and let off the button and let her roll out.Lots easier then the old heal/toe dump.
Old Nov 28, 2005 | 10:34 PM
How is the install? Difficult or not so...
Old Nov 28, 2005 | 10:43 PM
Steve Burger's Avatar
LS1TECH Sponsor
If you can bleed brakes it's not bad at all. The SLP kit I have had prebent lines. Run a few wires and happy line locking.
Old Nov 29, 2005 | 06:20 PM
01SLPSS's Avatar
Couldn't say it any better myself!!!!!
Old Nov 29, 2005 | 07:44 PM
badpewter-z's Avatar
LS1TECH Sponsor
works great and easy to do . put the switch in a convienet spot for you and let it rip
Old Nov 29, 2005 | 08:00 PM
SSDriver's Avatar
Works great. Best thing to add to a car with DR or slicks in my opinion. Makes burnouts a breeze at the track and saves wear/tear on the rear brakes.
-William
