Quick slave cyl question
Old Dec 12, 2005 | 07:15 AM
walwal63's Avatar
Default Quick slave cyl question
I have a 98 Camaro SS and I have to replace my slave cylinder, my question is, does the 02 slave bolt right in, and do I have to use the 02 master cylinder with it? Any help would be greatly appreciated.
Old Dec 12, 2005 | 12:18 PM
Robinator's Avatar
it is bolted in your transmission by 2 bolts. Un-bolt and re-bolt a new one in. You dont have to replace the master but for roughly $50 you can have a brand new 2002 master. Go down to Riebees(might be Napa there) and use a AAA discount. If you havent done it yet either, perfom the drill mod.
Old Dec 12, 2005 | 12:19 PM
Robinator's Avatar
BTW the 2 bolts that hold the slave on should only be torqued down to 6 ft/lbs and use a little locktite on the threads.
Old Dec 12, 2005 | 12:44 PM
walwal63's Avatar
excellent thanks for the info!
