what clutch???
Old Dec 18, 2005 | 03:06 PM
01Blk*SS*'s Avatar
Default what clutch???
my stock clutch is slipping every once in a while and i dont think its going to last long...... i want a good clutch and flywheel, would like to spend around $650 ....what would you guys suggest with the mods in my sig??? thanks
Old Dec 18, 2005 | 04:25 PM
LS1powerhouse02's Avatar
I just put my centerforce dual friction clutch in last night....i will let you know what i think of it. But i used centerforce b/c they have EXCELLENT customer service and i am a broke *** college student so i need all the help i can get! haha...But maybe look at the LS7 clutch...do a search on here and see what some people say about it. Hope this helps. Any more questions just let me know...good luck!
Old Dec 18, 2005 | 08:21 PM
02 Camaro SS's Avatar
I got a spec stage 3 and it's had no problem handling a few 5500 rpm clutch dumps on et streets. It's not bad at all on the street. All together with a resurfaced flywheel and installation it was a little over $800
Old Dec 18, 2005 | 11:51 PM
hammerhead's Avatar
If you're not planning on adding lots of power, the ZO6 is good. I just had one put in with an updated slave. works great. Nice clean car BTW. Looks like mine!
Old Dec 19, 2005 | 02:14 AM
01Blk*SS*'s Avatar
thanks, how are mc cleoud clutches??? what else should i upgrade when i do the clutch??? also what are some website i can buy this stuff off of ??? thanks for the input so far
Old Dec 19, 2005 | 05:50 PM
smontana16's Avatar
i had a spec stg 3 and it was worse on the street than my new spec stg 5. if you do the install yourself a stg 5 would be in you price range. plus theres no break in on a 5.
Old Dec 20, 2005 | 03:09 AM
01Blk*SS*'s Avatar
t.t.t.
Old Dec 20, 2005 | 03:14 AM
98turbls1's Avatar
I'm going to go with the Mcleod clutch but I have to tell you that they are quite pricey...The kit with the steel flywheel is like $1100 but I think that is going to be the twin disk...You can look at different clutches by clicking on some of the sponsors on the right...I've seen the Mcleod on speedinc.com and I believe Thunderracing too...Just shop around for something that fits you and keep asking questions until that little guy on your shoulder says to buy it
Old Dec 20, 2005 | 02:13 PM
01Blk*SS*'s Avatar
........ any other input?
Old Dec 20, 2005 | 02:15 PM
01Blk*SS*'s Avatar
what else should i change while i do the clutch??? how are the lightweight aluminum flywheels??? do they make a much bigger difference than the steel??? thanks
Old Dec 20, 2005 | 09:19 PM
01Blk*SS*'s Avatar
Old Dec 20, 2005 | 09:33 PM
01Blk*SS*'s Avatar
i do plan on adding a little more power to the car, nos??? full built suspension, etc would a aluminum fidanza flywheel together with a ram clutch be a good set up ??? also what ram clutch would be suggested??? the powergrip clutch or the ram hdx set??? thanks
Old Dec 20, 2005 | 09:58 PM
01Blk*SS*'s Avatar
around how long do the powergrip clutchs last??? i would only go to the track about once a month and it would be a daily driver??? thanks
Old Dec 20, 2005 | 10:02 PM
If you're man concern is drag racing, which it most likely is, then get the steel flywheel over the aluminum. Aluminum is good for road racing because it does let the engine rev faster and all but a steel flywheel stores more energy when you launch (more mass spinning at a given rpm). But do you plan on using any sticky tires and doing high rpm clutch dumps? If not, maybe an aluminum flywheel would be worth it. Maybe someone can jump in and clarify that point a little bit.
Old Dec 20, 2005 | 11:44 PM
01Blk*SS*'s Avatar
well i ordered the ram powergrip clutch with fidanza aluminum flywheel, i plan on dragging it but not anywhere near 5k drops, i still have the stock 10 bolt, but i will be running nitto 555r drag radials pretty soon...... anythink bad about that with the aluminum flywheel??? thanks
Old Dec 21, 2005 | 10:02 AM
01Blk*SS*'s Avatar
ttt...
Old Dec 22, 2005 | 03:50 AM
01Blk*SS*'s Avatar
Old Dec 23, 2005 | 01:52 AM
93octane's Avatar
Yeah, I'd be conscious of that 10 bolt with an aftermarket clutch and sticky tires.
Old Dec 25, 2005 | 03:46 PM
01Blk*SS*'s Avatar
i guess the peoiple i bought the clutch from sent me the powergrip hd instead of the regualr powergrip.... is the hd way less streetable than the regular??? thanks
Old Dec 26, 2005 | 07:26 PM
01Blk*SS*'s Avatar
t.t.t.
