Clutch Disc Size questions
Old 12-21-2005 | 08:39 PM
-=Jeff=-'s Avatar
Question Clutch Disc Size questions
From what I understand the LS1 F-bodys use an 11" Disc, Sprung hub with a 1-1/8" input shaft with 26 splines correct?
If so, I am in need of some help. I have an 89 Corvette I am going to install a clutch in. I need an 11" Sprung hub, 1-1/-26 Disc I have a New pressure plate and TO Bearing so all that is needed is a Disc.
I thought I could use the Ram 310M but it is 11" 1-5/32-26. I don't think the extra 1/32 will be a good thing on the input shaft.
I am curious to see what brands are avail. with the above specifics, I know SPEC does as I was looking at their Stage 3 disc, but my friend bought it last year for $150 and it is now $250. so beofre I finalize my decision I would like to see what else might be avail.
Thanks
