installing a pilot bearing, help
Im affraid I will mess up the face of the bearing. Any help would be great.
By the way I got it guys..
Just used a hammer and tapped it in gently, doesnt mar or dent the surface at all. If you tap it in a circular motion you can actualy here where you need to hit cause it doesnt sound solid then once it makes a dense noise move on to another spot.
Hope this helps someone in the future.
If you use a socket just under the outside diamater of the bearing and a 6 inch extension, you can just tap in with a hammer.
Yes and smother the inside of the bearing with more grease, as the grease it comes with is not enough.
Hope this helps
Dave
and on these cars the pilot bearing dosent go in the flywheel. it goes behind it (sorta)
Out meaning when you guide the input shaft of the trans into it it will guide it self with the taper. And just put the bearing flush with the lip of the crank also.
