t56 questions
Old Jan 8, 2006 | 09:08 PM
southsidehacker's Avatar
Default t56 questions
I have a couple quick questions regarding the t-56. My buddy is swappin a t-56 from a 95 camaro into a 89 Iroc. There's a treaded hole on the left side of the trans pointing downwards in front of the the VSS almost at the top of the trans. What the hell is this hole for??
Old Jan 9, 2006 | 07:05 AM
calhoon's Avatar
If it is a threaded hole approx. 1.5 inch dia. its the skip shift solenoid hole. This is located just below the cover plate on the driver side.
Old Jan 9, 2006 | 05:52 PM
Can I eliminate it? What thread size is the hole? Thanks
Old Jan 10, 2006 | 07:35 AM
calhoon's Avatar
You can eliminate it if your ECM does not require it in its control logic(if you have the '89 ECM its not needed in there). It has an M20x1.5 -6G thread. Ithink you will have a difficult time finding a ready-made plug for this ( other than a plastic shipping-type plug) I suggest you either turn one from aluminum hex stock or instal the solenoid ( easiest) . BTW there is an O ring used on the solenoid and it should also be used on a fabricated plug if leak abatement is important.
Old Jan 10, 2006 | 06:07 PM
the car is running "Big Stuff" electronics, so it's not required. I going back to work to mill a plug up right know. Thanks for your help
