clunks while engaging and disengaging clutch..ideas??`
Old 01-14-2006, 10:04 AM
bowtieman81's Avatar
Well, I have a clunk sometimes when changing gears, but I know for a fact mine is the rear end slop. I have the stocker 10 bolt. Reason I know is before I got the car tuned I would get bucking at low rpm with the clutch engaged. Well, guess what I heard when the bucking happened: clunk, clunk, clunk every time is it would buck back and forth.
I have checked the rest of my suspension setup, nothing is wrong with it.
Old 01-14-2006, 10:20 AM
ninobrn99's Avatar
well hopefully it will go away with the 9" install. If not, then lets see if my new master cylinder does anything for it.
Old 01-14-2006, 08:27 PM
bigdsz's Avatar
I just found out that even with the 01+ upgraded hydraulics it is necessary to do the drill mod. Is this in fact correct? I thought when you put in the new master/slave the drill mod was unnecessary. Perhaps this is part of my problem.
Old 01-14-2006, 08:39 PM
ninobrn99's Avatar
yes, you have to do the drill mod with them all. from what i was told they're the same. its the slave that was changed, but people will still argue that. however, the drill mod is needed, the 01-02 are just built better if they are indeed different.
Old 01-14-2006, 08:49 PM
ninobrn99's Avatar
so no one here has the the drill mod done? im going to change my master out as soon as i can and let you all know what happenes...can someone else try to do it to theirs and see if it helps? if someone has it done and is still having this problem, then let us know so we can eliminate that route.
Old 01-15-2006, 05:21 PM
Kleeborp the Moderator™
MeentSS02's Avatar
I'm just gonna wait until Textralia comes out with their stainless, quick disconnect line that has no restrictors whatsoever in it.
Old 01-15-2006, 05:38 PM
ninobrn99's Avatar
when is that supposed to come out?
Old 01-16-2006, 01:04 AM
kidkl's Avatar
Same thing here:
Textralia with billet flywheel
Drill mod stock 2002 master new slave.
Prothane Tranny Mount.
Old 01-16-2006, 05:30 AM
MeentSS02's Avatar
Prolly within the next month or so...I think someone has already sent them the F-body line so they can do it. They already exist for Vettes and GTOs (I think).
Old 01-16-2006, 09:56 AM
ninobrn99's Avatar
well i dont have that kinda time oh well, we'll see what happens with the new stuff. It may be the slave causing the issue...cause kidkl has a new master w/ the drill mod and is showing the same problem. Could it be the slave cylinder? I mean it shoots in and out when you press the clutch right?? and thats what the sound resembles right? hmm....
Old 03-11-2006, 09:15 AM
ninobrn99's Avatar
just an update. i replaced the master cylinder and it still did it. just got the slave replaced, but i cant test it cause im deployed. my wife will be doing it for me though, so ill post up and let everyone know if it helped. my slave was shot so i also got another clutch because im pretty sure it developed unever wear and messed up my pressure plate, so its not entierly just the slave that was replaced, but i know it wasnt the master.
Old 03-11-2006, 01:44 PM
  #32
DONAIMIAN's Avatar
Originally Posted by rich Z
Get a poly trans mount and it will go away.
I have a poly mount and it does it. I have no clue what it is, but I think its related to aftermarket clutches more than anything.
Old 03-12-2006, 10:04 AM
  #33
ninobrn99's Avatar
hopefully i can get my wife to test it out today and ill post up results when i can..it may also be best if i have her test it for a few days, then post up...the symptoms should show right away if they're there, but still...
Old 03-18-2006, 01:38 PM
  #34
ninobrn99's Avatar
ok, new clutch, new M/C, new slave, resurfaced flywheel, stock flywheel bolts, new driveshaft, transmission mount, and rearend...STILL CLUNKING!! my wife told me that it did it going into third gear...well gents, this only leaves one piece of the puzzle on the table...yup! the tranny... what else could it be? I hope a rebuild can fix it!
Old 11-25-2008, 10:43 AM
  #35
ElChiefWS602's Avatar
ANyone ever figure this out? I am having the same problem.
All less than 5k miles:
Six Speed Inc trans
Tex OZ700
RSG NWB
New master and slave, no drill mod
S60 (checked)
Strange Driveshaft (checked)
Prothane motor mounts
Prothane trans mount
Prothane T/A mount
Stock T/A (good shape)
UMI panhard bar (poly/rod)
UMI LCAs (poly/rod)
KYB GR2 rear shocks
SLP bolt in sub frames
Wheels balanced
Still clunks while shifting and blipping throttle and have a high speed vibration over 80mph.
Suggestions?
Quick Reply: clunks while engaging and disengaging clutch..ideas??`
