1/2 way thru clutch install
Well it took two freaking days but I finally got the trans, bell housing, pressure plate, clutch and flywheel off the car. Some of the top bolts are a big PITA. And when I was taking off the bell housing yesterday I found that I snapped the wires that connects to the clip for the skip shift...oops Tried looking for new clips to go into the clip, but no luck. I think I will just butt connect the 2.2k ohm resitor to the wires, that should do the trick. Then to the bell housing man was that a PITA to break loose the pin on the passenger side was rusted which didn't help much. So today I will get the flywheel resurfaced and then next weekend will start putting everything back together. Wish me luck..I will fill you in on the results next monday...Michael
Re: 1/2 way thru clutch install
Good Luck with it....what kind of clutch did you decide to go with....I'm sure its something pretty beefy to handle the bottle... <img src="gr_stretch.gif" border="0">
Dont get discouraged. The 1st time i did it took me the same amount of time. The last time I did it, I started at 10:30am and at 1:30pm I was reinstalling the flywheel that I had just went and gotten turned!! Take your time and dont forget to locktite the pressure plate bolts. I did forget but hopefully it will be ok <img src="gr_stretch.gif" border="0">
cablebandit Thanks for the encouragment...reading your post brought a little releif to the matter. I will pick up the red and blue loctite today when I have the flywheel resurfaced. Thanks again..Michael
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
