View Poll Results: Which gear do you drive in from 55mph to about 62 mph on the highway.
I drive in 5th gear
197
24.35%
I drive in 6th gear
612
75.65%
Voters: 809. You may not vote on this poll
5th or 6th gear on highway??
Old 04-15-2006, 11:19 AM
  #81
Orange99Z's Avatar
6th with my 4.11's
5th until around 70mph when it was stock.
Old 04-18-2006, 08:27 PM
  #82
sdm1234's Avatar
Originally Posted by orangeapeel
You definitely dont want to run too low RPM's under a load though. It causes some crank stress if I am not mistaken.
Correct, along with other internals.
Originally Posted by Wesmanw02
There's no harm in that at all, so long as the engine isn't bogging/struggling.
It may feel that way, but as many people know, feelings can be deceiving. One example is that many people don't feel/hear a knock until the computer tells them so.
Originally Posted by GETGONE
According to your philosophy, the car idling at 800rpm or so is bad for it then? Oh..and I dont' skip 4 gears..I skip 5. I'll full throttle to 40-45mph in first then drop it in 6th and cruise along. 18K miles and not a hiccup yet. No oil use, no heistation, just great power and mileage. I'm not trying to skip any load. I get it up to speed and then cruise in 6th. If/when something breaks or goes wrong I'll be sure you're the first to know ok?
18K miles is still like breaking the car in lol. give it time and you'll start experiencing problems and you'll wonder why your engine components are faulty at such a young age. When that happens, please contact me because I'd love to hear what the problems are and how you diagnose them. Full throttle from 1st to 6th only sounds good on a -10% road grade. There is a difference between "hard" miles and "easy" miles on the motor ya know.
Old 04-18-2006, 09:28 PM
  #83
mdma z28's Avatar
I generally won't go into 6th until I'm going 70, it bogs entirely too much and honestly I think it puts more engine load in 6th at too low of rpms rather than 5th at higher rpms.
Old 04-18-2006, 11:19 PM
  #84
Wesmanw02's Avatar
Its really not a big deal so long as you're not having to give it too much throttle input to keep it going. If you're just touching the gas and its cruising along at 1200RPM, its not a problem at all.
However, if you have to give it more than just light throttle input to maintain speed, definitely downshift
Old 04-28-2006, 12:21 PM
  #85
great421's Avatar
Default thumping noise
Originally Posted by tappy
I drive mine in 5th because i have that tricky thumping noise i cant figure out at 1500rpm
Get the following poly bushings from Energy Suspensions:
a Front Torque Arm (BTW - Use lots of lube on this one! It's Tight!)
Pan Rod
Lower Control Arm
The addition of these 7 bushings eliminated 95% of my Formula's thumping and low rpm / high gear driveline shake.
MIKE
Old 05-05-2006, 11:55 AM
  #86
Cali SS's Avatar
I drive in 6th in hopes of conserving gas, lol.
Old 05-06-2006, 05:00 PM
  #87
BriancWS6's Avatar
I didn't read through all of this, but it says in the manual that you can shift into 6th at 49mph. Now I am not saying this is the end all way to do it, but on a stock or bolt on car it's not gonna hurt it to cruise at this lower rpm. Now a cammed car is a diff story. I say go by the feel, and don't let it lug too hard. I use 6th at 55 and if it's flat at even slower speeds, like in the 40s when I am grandpa'ing around
Old 05-10-2006, 10:06 PM
  #88
Born_Ready99's Avatar
Originally Posted by 87Fake
I just go by feel. If it feels like its chugging in 6th, then its too much load and probobly eating more fuel than if it were in a lower gear. For me, on the highway I'm in 6th, like 60-65 and above. But with my cam and stock gears I can't hold 6th to lower speeds.
I agree, I have a stock 99' WS6 and I just go by how it feels, if I start going up hill I go to 5th, and downhill normally is 6th...It just depends.
Old 05-11-2006, 11:19 AM
  #89
2000WhiteTA's Avatar
I am in 6th gear everywhere I go. I have 4.11 gears and I shift into 6th at 45 mph. I like to get good gas mileage so it is always in 6th gear.
Old 05-16-2006, 06:32 PM
  #90
z28drag's Avatar
6th gear? wow my car whants to stall @ 65-70 mph.
Old 05-16-2006, 06:49 PM
  #91
Domestic Demon's Avatar
Same here, I have 4.10's as well
Old 05-17-2006, 04:25 PM
  #92
ssman00's Avatar
50 and up I live in sixth gotta conserve that gas it does fine at that speed
Old 07-23-2006, 10:22 AM
  #93
NOIR's Avatar
60+ is in 6th. To keep the RPM's right around the 1200-1500 mark, and 2k when you really start moving.
Old 07-24-2006, 02:10 PM
  #94
BLK02TA's Avatar
For me it all depends. Right now I'm kind in the Las Vegas/LA area and when going up hill I usually drop down to 5th. But when crusing about 65 on pretty level ground I'll stay in 6th.
Old 07-28-2006, 05:42 PM
  #95
gun5l1ng3r's Avatar
Doesn't the tune of the car effect how it runs at low RPMS? I have a 1998, the year with the supposedly "defective" knock sensors and I always have to wait until 65MPH to go to 6th otherwise it feels very sluggish.
Could faulty knock sensors cause the computer to pull timing and reduce my low RPM torque?
I don't have EFI Live or any other software to monitor knock, so I don't know if my Knock Sensors are even working correctly.
Old 07-30-2006, 01:14 AM
  #96
2002_Z28_Six_Speed's Avatar
You could try getting a scanmaster. They are cheaper.
I always look at the MAF reading before and after changing gears to determine which gear I am using. If it reads too high I downshift and I was actually suprised to find out how many times I saved fuel from downshifting.
Old 08-08-2006, 12:32 PM
  #97
spazzyfry123's Avatar
I drive in 6th since I have 4.11's Pretty pointless to ride at such a high RPM in 5th.
But when I had my 3.42's in there, I would be in 5th at those speeds since it would be putting too much stress on everything seeing that it was only a few 100 RPM higher than idle
Old 08-08-2006, 10:05 PM
  #98
NitoV's Avatar
I shift to 6th @ 45. She doesn't bog one bit and I average 24mpg, so I'll keep this up.
Old 08-09-2006, 01:24 PM
  #99
chris2000ss's Avatar
I drive in 6th gear !!!
Old 08-09-2006, 02:55 PM
  #100
megawayne's Avatar
6th gear here at 55.
Quick Reply: 5th or 6th gear on highway??
