Slipping out of third gear
File In Section: 07 - Transmission/Transaxle
Bulletin No.: 01-07-29-003A
Date: May, 2001
TECHNICAL
Subject:
Transmission Jumps Out of 3rd Gear (Replace Shift Fork, 3-4
Synchronizer Assembly, 3rd Gear Blocker Ring and 3rd Speed Gear)
Models:
1999-2000 Chevrolet Camaro
1999-2000 Pontiac Firebird
with Manual Transmission (RPO MM6)
This bulletin is being revised due to a change in part numbers. Please discard Corporate Bulletin Number 01-07-29-003 (Section 07 - Transmission/Transaxle).
Condition
Some owners may comment that the transmission jumps out of 3rd gear.
Cause
Condition may be caused by inadequate travel of the 3-4 synchronizer assembly due to the 3-4 shift fork being out of specification or bent.
Correction
Notice : Please review the appropriate section of the Transmission Unit Repair Manual for correct disassembly and assembly instructions. When performing this bulletin, ALL parts listed need to be replaced. The condition originally occurs because of the 3-4 shift fork being out of specification or bent. This eventually results in damage to the synchronizer assembly, the blocker ring and the speed gear. Replace the 3-4 synchronizer assembly, the 3rd gear blocker ring, the 3rd speed gear and the 3-4 shift fork.
Part # Description Qty
12523207 3-4 Shift Fork 1
12523078 3/4 Synchronizer Assembly 1
12523186 3rd Gear Blocker Ring 1
12523077 3rd Speed Gear 1
Also would this be cheaper if I bought those parts and took it to a tranny shop. Is this really hard for a normal person to do. I dobut I could do it but kind of short on cash right now. thanks
While you've got the trans out it and they're rebuilding it I'd check the clutch condition, slave cylinder condition, and the pilot bearing. Maybe even replace the pilot. It's cheap and it's easy to do.
