Where exactly is the clutch bleed valve (already tried "search")
1 Post
May sound stupid.....but where EXACTLY is the clutch bleed screw. I am checkng my master cylinder to see if it's good/bad before pulling the trans for my clutch problem. I read that if the bleed valve isn't opened, I may not be able to get the QD from the master to the trans back in. Ok. I found the master cylinder line and QD into the trans. That was easy. I "thought" the clutch bleed valve was above this near the top of the trans. I couldn't feel it. I was feeling for a bleed nipple like on the brakes (7mm I believe?). I was feeling for it on the trans near the junction with the bellhousing. Am I even close? I'm doing this on my back with the car on ramps. Any info (or pictures) would be of great help right now. Thanks.
1 Post
Geez, I was looking right at it and didn't realize what it was! Thanks for the pic, that helps a lot.
Now I can only hope my master cylinder is BAD.....because then I won't have to pull everything apart........
1 Post
Originally Posted by Ls1Envy
When you bleed this doesnt fluid drip down into the bellhousing and ruin your clutch!??!
