Burnouts with M6?
Car never gets sideways, never hit the rev limiter, dont have to do any heel toe (id f' it up in a second if I tried that) and never have a problem besides going through rear pads (linelock will come soon enough)
And you have to turn off T/C or else the car will just bog down and stall
steps:
1.Take your Left foot and fully push in the clutch while the instep of your right foot pushes on the right lower portion of your brake pedal.
2.Rock your right foot forward while still holding the brake with your instep and with the tows portion of your foot push the pedal untill the engine is about 3500 to 4000 rpm's.
3. dump clutch and while still holding brake(if car moves forward not enough pressure on brake pedal) with instep and towing revs up above 4000 rpms. BAMBOOZIL you have a brakestand.
4.After u see smoke poor take instep off brake and mash into the gas pedal for a pro-stock like burnout up to the line. wallah.
5.itll take a couple tries dont give up after ur first try have fun!
-Krab <------ has a "loose" lazy @$$ mullet
you ever seen the sparks flying off the rotor when someone does that? i can see, though, how the line lock could become the new fad, like the N2O purge is now, lol.
The hard part is not bouncing off the rev limit. I usually end up with a patch about 3 ft long for first no matter how long I hold the rev, and then I start to get a little traction in 2nd but can keep 'em spinning good for 30 feet. I better have some room in front of me when I hit 3rd though, 'cause she's gonna want to go, go, go...
Then again, this could be the reason I went throught the stock tranny.
