Burnouts with M6?
Ah, you beat me to it, but isnt 4000rpms a lil too much? Usually under 3k is all it takes
, rev car to 6k, move left foot to side letting pedal slap up, and sit there
until you blow both tires or can't breath anymore
.If no line lock you'll have to use the heel and toe method. Trending Topics
Like the guy above said. You dump the clutch and right away put your left foot on the brake. You'll feal right away if your pushing to hard or not enough. Also DO IT IN 2nd gear, and you dont have to romp the brake either.
.If no line lock you'll have to use the heel and toe method.You just don't realize how handy a linelock is until you start to use it. Once you do, you'll never want to go back. Great mod.
not to mention what you will spend in rear break pads will eventually be more than the line lock. i believe slp has one for around $130. i had to spend around $200 on mine (corvette tax) but still worth every penny.
.If no line lock you'll have to use the heel and toe method.I've done that. Went with option A. Blew out a tire. That was fun.
Right foot operates the brake with your heel and the gas with your toe.....making it a heel and toe method
