Stock Clutch
Old Mar 25, 2002 | 03:48 PM
vetteair's Avatar
Default Stock Clutch
Have a 2001 LS1 6 spd, that has 6000 miles. Upon inspecting the clutch ***. i found the disk to look like new.The pressure plate looked good but is slightly convexed (higher outside than on the inside of contact surface). The flywheel looked good no heat marks or cracks, but is convexed similiar to pressure plate but a little more extreme. Also on the flywheel there are 3 heavy wear marks equally spaced that match the 3 extra fingers on the pressure plate. Is this normal? Can i resurface the flywheel and reuse the disk and pressure plate? I'm not going racing with this stuff, but will see "fun" street use.
<small>[ March 27, 2002, 01:32 PM: Message edited by: vetteair ]</small>
Old Mar 27, 2002 | 02:47 PM
vetteair's Avatar
Default Re: Stock Clutch
Is anyone out there
