Swapping from A4 to M6
Old Mar 15, 2006 | 05:36 AM
White.Lightning's Avatar
Originally Posted by Superman09
Well what i am wondering is, is it possible to get every option with the swap. Like for example something about reverse lockout and traction control were said. Id like to have all the options like reverse lockout. I dont really need cruise control as i dont use it much anyhow. Traction control isnt totally necessary either as i try not to drive my car in bad weather and thats only when i'd need it. However since i will be a new M6 driver, id like reverse lockout so i dont accidently throw it in R. haha. So what im getting at, what options are not possibl to get with the swap? Unless they all are. Thanks!
Don't quote me, but I would think if the harness was spliced correctly then the reverse lockout would work?!?
Andy
Old Mar 15, 2006 | 06:26 AM
JakeY2KZ's Avatar
As long as you wire it correctly, reverse lockout will work. Just follow the writeups and you'll be fine. Mine looks everything like it would if you looked at a factory M6. My reverse lockout works, ASR/TCS works, etc. etc.
Old Mar 15, 2006 | 11:27 AM
Superman09's Avatar
LS1Tech Sponsor
Ok thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
