Swapping from A4 to M6
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
He will hook you up with what you need as far as a T56 transmission
2. Clutch- arguably the three "best" choices for that kind of power are:
Spec 5
McLeod twin disc
Texraillia
These clutches are made to hold the power. I personally have the McLeod twin, and it feels like stock. I have heard the same about the Spec 5 and Texrallia from people who have those clutches.
3. You will also need:
M6 center console
M6 pedal assembly
M6 hydraulics system- slave, master cyl., etc
Shifter
M6 harness OR splice your A4 harness- search for that info
PCM has to be flashed- dealership is the only way to change your VIN. I hope you know someone who works for GM
M6 trans crossmember?
T56 trans mount
Longer/shorter? driveshaft
I think thats it, someone correct me if I am wrong
This is a fairly involved swap. Good luck!
Andy
I did this 1 1/2 months ago. 3 of us tackled this job not having any experience doing this before. But between the 3 of us, we've done plenty of DIY projects. Tons of cam swaps, heads, you name it we've done it. By just looking at the threads in here, and a couple of write-ups, we sucessfully did it in 3 days. We ran into a couple of minor problems (slave problems, forgot bearings and on weekends was hard to get) it wasn't that bad. We could have easily got it done in less then 2 days. Just follow the writeup's and it should be a breeze. Hardest part was breaking down the bottom dash and getting the pedals in. Just make sure to take out the column as it gives a lot more room to work with.
As for the sensors, I was able to swap my harness for a M6 harness which made it a lot easier. I would recommend trying to find a M6 guy wanting to go to an A4, that way you can just take everything you need and swap them over. But if you can't, the information in the sticky thread above was all we needed when it came to wiring everything up.
I still have one problem left though which is my cruise control isn't working. I know the problem but just haven't got underneath there and fixed it yet.
1. Original slave busted when putting the tranny back in. I guess the shim wasn't correctly in place and when we started bleeding it, pressure built up and cracked it. Point taken here, make sure to have the shim in place or you will have bleeding problems. We had drop the tranny 3 different times to find out this was the problem after we were getting no pressure on the clutch when trying to bleed it.
2. Forgot that we needed a pilot bearing. Hard to find at local autoparts stores. Thank god we found someone with one in the area.
3. Tools, tools, tools. I swear it was like every little thing that we needed we didn't have. Make sure to have a sawzaw. I bought a metal grinder to cut the hole, but sparks will fly everywhere. Almost caught the interior on fire from it. lol Make sure you have wire for all the wiring along with connectors. Have a 1 1/2" hole saw for drilling for the master cylinder. Things that we didn't think of at first and had to drive to stores to look for all this stuff. Could have easily saved us about 3-4 hrs with the swap if we had everything ready.
4. My exhaust was welded before so that was a big pita when dropping the tranny so many times. Make sure that everything is perfect before clamping/welding the exhaust back up. You should see mine now, I have about 5-6 clamps on my exhaust right now. lol
5. Cruise control is not working still along with a SES light for a clutch position switch. I know what the problem of this is which is I forgot one connector on the back of the clutch. Without this being hooked up cruise control will not work, same reason why I am getting a SES light. Just need to figure out where to wire it to.
I did it in 3 steps: first the pedals then the tranny, then the rear end.
In the sticky on top of this section you'll find everything you need.
I kept the A4 harness: no problems with that.
Andy
