losing 5th and reverse
Old Mar 10, 2006 | 09:39 PM
Smoke Panther's Avatar
Default losing 5th and reverse
my car popped out of 5th gear earlier today...Ever since then, it's had problems engaging in 5th and reverse. I'll have to play w/ the clutch..and even after that, it grinds like no other going into the gear. Any input as far as causation, repair costs, parts needed, etc?
Old Mar 11, 2006 | 01:36 PM
Alrighty, just got back from taking a test-drive to see if it's still missing. Sure was, so I decided to use the ancient and lost technique of double-clutching and it works just fine doin that....looks like it's the synchro on that cluster. Anyone have any clue how much a new one would cost or if this is something a professional should handle or not?
Old Mar 11, 2006 | 01:39 PM
DONAIMIAN's Avatar
Look at the fluid in your clutch resivior, what color is it?
Old Mar 11, 2006 | 03:42 PM
brown and murky
Old Mar 11, 2006 | 05:24 PM
Bill's 02 Z-28 SS's Avatar
I believe it should clear but it popping out of 5th sounds like a transmission issue not a clutch. Maybe the color indicates over heating of the clutch but get the transmission checkout soon.
Bill
Old Mar 11, 2006 | 06:02 PM
DONAIMIAN's Avatar
Originally Posted by Smoke Panther
brown and murky
flush it, should be the same color as the your brake fluid.
Old Mar 11, 2006 | 07:21 PM
Noted...I'll try that and let yall know what's up
